1.5" conversion kit question's
Lownslowlsc
N il
1st is how tall will it sit if you measure from the ground to the bottom of the fender once it settles?
Had a second but found it.
I'm still searching but not coming up with much.
im assuming you are talking about a 1.5'' lowering kit, not sure what the exact height off the ground is but on my car you can just fit a beer can in between the rocker panel and the ground.
fender there is about a half inch between it and the tire. maybe 3/4'' in the rear.
ok, only reason i ask is cause of the 19's. Dont want to much fender gap. I'll have to find a way to convert it i guess. thanks.
i got 17's with 255/45's in the front and 275/40's in the rear, and the 1/2'' in the front and 3/4'' in the rear is about the gap i have between the tire and fender. don't know if that helps at all?
