06 ls throttle body
Max, ad to the right.
Why do you need one? The LS is known for throwing false throttle body codes when the problem is really a bad COP (Coil On Plug), usually #4.
well the tech says the readings are wrong, thinks the motor is not closing it off like it should and causing it to go into the limp mode,i have changed about 1/2 the coils on this one. they are using a ford scanner to see what it is going live.
the problem is that when the coil is failing it can produce interference that gets picked up by close wiring in the car and the cars computer thinks that the problem is something different than what it is. i would think that the interference would fool with the ford scanner the same way since it is just reading what the cars sensors are showing.
i'm just sating, we have seen a few TB's replaced and the problem not fixed because of it, the 06's are not know for having faulty TB like some of the earlier models are
yeah that is a worry, i have 2 06's, just hate to tamper with my new one, bought it to replace the one with the problems, seems the first one has always had something going on since the day i got it home, so far the replace has had zero problems ! guess if it comes down to it i can switch the throttle bodies and see what happens .......
i would first try to swap around some of the coils (not from car to car) i would take coils 3 & 4 and switch them with coils 5 & 6 and see if the failsafe mode goes away
