D
Dfonner
Guest
My 04 V8 LS cooling fan barely turns and the car overheats because of it. I have tested that the fan is fully functional by bypassing any control and I am able to get the fan to come on full blast by doing so. I have also checked to ensure that the ecu is sending a signal to fan to activate it and it appears to do so. My question is this- where is the fan control module located? Would a faulty control module cause my fan to act this way?
If I run the heater, the temp stays in the operating range and does not overheat and no error codes are being thrown.
Any thoughts, guidance, suggestions?
Thank you,
Fonner
Thank you,
Fonner
