Nope, just unscrew it at the EGR and pull the steel tube out of the way.Thanks for the feedback. I have the new Motorcraft EGR assembly in-hand, and it does include the shim gasket and new bolts. At first glance, it appeared that the steel EGR tube had to be removed in assembly with the EGR valve, and then disassembled on the bench. I'll give it another look tonight.
Thanks!
JD
