02 V6 LS Evap code p0453?
deathgeeble
LA
I have Evap code p0453 ,
Open on FTP sensor signal wire
Short to voltage on FTP sensor signal wire
Bad FTP sensor
Abnormally high pressure in fuel tank due to blockage in EVAP purge hoses or overfilled tank
Loose/damaged FTP sensor connector
Loss of ground to the sensor
I guess those can be the problems. Has anyone had this code come up and if so can you help me out. I also have no idea where the ftp sensor or Evap purge hoses are located .
Thank You
