01V6 148k miles a few recent notes
tireman
atlanta
replaced pads and rotors but developed a squeal. Checked air in stock size tires at 28psi, inflated to 35psi, no more squeal. Tires only have 3/32nd tread, so the loss of inflation must have put some lateral pressure on the pads. ????
my black pillars were coated with oxidation, and looked aged along with my door rubber deck trim. So I got out the turtle wax polishing compound and buffer. lathered up the pillars with compound and lightly buffed till clean, wow! all new again!
use 210 grit sandpaper to lightly sand off the deck trim rubber blistering and treat with back to black solution. looks much better.
proud owner since 2001
