00 LS airbag module location?
Snowseeker
Stevens Point
Anyone know where the air bag module is on a 00 ls? Is it under the drivers seat like it normally is?
Air Bag and Safety Belt Pretensioner Supplemental Restraint System (SRS)
The air bag supplemental restraint system (SRS) is designed to provide increased collision protection for front seat occupants in addition to that provided by the three-point safety belt system. Safety belt use is necessary to obtain the best occupant protection and to receive the full advantages of the SRS.
The air bag supplemental restraint system (SRS) components are shown in the following illustration.
Air Bag Supplemental Restraint System (SRS) Components
Item Part Number Description
1 044A74 Passenger air bag module
2 14B345 Side impact sensor (RH)
3 611B08 Belt retractor pretensioner, passenger
4 611D10 Passenger side air bag module
5 14B321 Restraints control module (RCM)
6 043B13 Driver air bag module
7 611B09 Belt retractor pretensioner, driver
8 14A664 Clockspring
9 611D11 Driver side air bag module
10 14B345 Side impact sensor (LH)
Driver Air Bag Module
NOTE: References to the driver air bag module must not be confused with the seat-mounted air bag components of the supplemental restraint system (SRS).
The driver air bag module:
is steering wheel mounted.
will deploy upon receiving a signal from the RCM.
has no subassemblies.
Clockspring
The clockspring:
is mounted on the steering column, behind the steering wheel.
provides a continuous electrical path from the driver air bag module to the restraints control module (RCM).
Driver Seat Side Air Bag Module
NOTE: References to side air bag modules refer to the seat-mounted and not to the steering wheel or instrument panel mounted air bag components of the supplemental restraint system (SRS).
The driver seat side air bag module:
is installed as an assembly.
is mounted in the driver seat back.
Passenger Seat Side Air Bag Module
The passenger seat side air bag module:
is mounted in the passenger seat back.
Passenger Air Bag Module
NOTE: References to the passenger air bag module must not be confused with the seat-mounted air bag components of the supplemental restraint system (SRS).
The passenger air bag module:
is mounted in the passenger side of the instrument panel.
Safety Belt Pretensioners
As part of the supplemental restraint system (SRS), the safety belt retractors are equipped with pretensioners. The safety belt retractor pretensioners rotate the safety belt retractors to remove excess slack from the safety belt webbing. The pretensioners are activated by the restraints control module (RCM) when the module detects a crash event force exceeding a programmed limit.
Restraints Control Module (RCM)
The restraints control module (RCM) is mounted on the center tunnel under the instrument panel. The RCM performs the following functions:
signals the inflators to deploy the air bags in the event of a deployable crash.
activates the belt retractor pretensioners to remove slack from the safety belt webbing.
monitors the air bag supplemental restraint system (SRS) for faults.
illuminates the air bag indicator if a fault is detected.
flashes the air bag indicator to indicate the lamp fault code (LFC) detected.
communicates the current or historical diagnostic trouble codes (DTCs) through the data link connector (DLC).
signals the instrument cluster to activate a chime if the air bag indicator is not available and another SRS fault exists.
contains an internal safing sensor which is not serviced separately.
The RCM monitors the SRS for possible faults. If a fault is detected while the ignition switch is in the RUN position, the RCM will illuminate the air bag indicator located in the instrument cluster.
When the ignition is cycled (turned off and then on), the air bag indicator will remain lit for six seconds and then go out. If an SRS fault exists, the air bag indicator will then flash the two-digit LFC associated with that fault. The air bag indicator will flash the LFC five times, then remain illuminated for the rest of the key cycle. The RCM will also communicate the current and historical DTCs through the data link connector (DLC), using the New Generation Star (NGS) Tester. If the air bag indicator does not function, and the system detects a fault condition, the RCM will signal the instrument cluster to activate an audible chime. The chime is a series of five sets of five tone bursts. If the chime is heard, the SRS and the air bag indicator require repair.
LFCs are prioritized. If two or more faults occur at the same time, the fault having the highest priority will be displayed first. After that fault has been corrected, the next highest priority fault will be displayed.
The RCM includes a backup power supply. This feature provides sufficient backup power to deploy the air bags and belt retractor pretensioners in the event that the ignition circuit is damaged in a collision before the safing and air bag sensors determine that an air bag deployment is required. The backup power supply will deplete its stored energy approximately one minute after the battery ground cable is disconnected.
Electrical System
The electrical system that supports the air bag supplemental restraint system (SRS):
is powered from the battery through the ignition circuit.
provides the electrical path from the restraints control module (RCM) to the SRS components.
provides the electrical path from the RCM to the air bag indicator.
provides the electrical path from the RCM to the data link connector (DLC).
provides the electrical path from the RCM to the instrument cluster.
Sensors
WARNING: The restraints control module (RCM) orientation is critical for proper system operation. If a vehicle equipped with an air bag supplemental restraint system (SRS) has been involved in a collision in which the center tunnel area has been damaged, inspect the mounting and bracket for deformation. If damaged, the RCM must be replaced whether or not the air bags have deployed. In addition, make sure the area of the RCM mounting is restored to its original production configuration.
CAUTION: Sensors are repaired by replacement only. Do not attempt to determine whether a sensor is OK. Always replace the sensor even if it does not appear to be damaged.
For this vehicle the SRS employs four impact sensors. Two of the sensors are integral to the RCM and are not separately serviceable. In addition, there are two side impact sensors located at the base of the B-pillars. The RCM is mounted on the center tunnel under the instrument panel. Mounting orientation is critical for correct operation of all impact sensors.
Perfect!! Thanks so much! I guess they don't call the modules anymore but SRS or RCM controlers.
If your airbag light is on it might not be anything wrong with the module. Their is a common problem with the LS and it is the clockspring and it cause the light to come on. If it flashes I think the code is 32 that is your problem. Just trying to save you a little headache.
Well I am kinda thinking that the airbags being poped might have something to do with the light being on. :p
I just wanted to know where it is so I won't have to look for an hour when I am going to replace it.
