For Sale 2000 Lincoln LS, 3.0, 5-Speed manual
LSinYourLS
Virginia
For sale: 2000 Lincoln LS, 3.0, 5-Speed manual - RARE!
Pictures at: http://roanoke.craigslist.org/cto/5676041153.html
Only 2300 LS sedans came with a 5-speed manual transmission, this example has been well-cared for, with 202,650 mostly highway miles.
Since buying this car 3 years ago I have installed the following:
Upper & lower front control arms.
Outer tie-rod ends.
All 4 shocks.
Motor mounts.
Radiator.
Water pump & cooling hoses.
DCCV valve.
New factory radio.
Transmission, clutch, and flywheel.
New valve cover gaskets, intakes gaskets, and oil pan gasket.
All ignition coils and spark plugs.
Front & rear pads and rotors.
All synthetic oil for engine, transmission, and differential.
New seat cushions for front driver and passenger seats.
Additionally, I have retrofitted FACTORY heated seats, HID headlamps, as well as an auxiliary audio in jack.
The vehicle will come mounted with 245/45ZR18 on Ford Fusion Rims (18x8, 55mm offset), plasti-dipped Anthracite Metallic, on custom made 5x108 8mm spacers with bore centering lip for the wheel. As well as winter wheel setup: 225/50/17 Firestone Winterforce snow tires mounted on factory 17inch sport rims, WITH full sized spare. I'll also include a factory Lincoln car cover.
ADDTIONALLY, for LincolnVCadillac members, I'll include for FREE my limited slip setup as seen here:http://www.lincolnvscadillac.com/forum/showthread.php?98787-Brand-new-Limited-Slip-diff-for-sale
