mikeyg03ls
Hey guys, I have already done some searching on the site and priced things out but I'm looking for advice/ Tips on replacement of some parts and maybe some pricing help if people know where to get things cheaper? I got my 03 on a lift today and found out I need 3(might as well do 4) sway bar links, 4 sway bar bushings (not sure of the size if anyone happens to know the second gen size(, 1 rear lateral arm, drivers side upper ball joint, and 2 carrier bearings for the rear diff. I can get everything but the ball joint from rockauto besides the bushings and the ball joint which I believe you need the whole upper arm after reading around.
Rock auto prices:
1 Deeza Lateral arm: $84
4 Moog Links: $120
2 Timken bearings: $23
2 Front sway bar bushings: $40 from energy suspension
Total with shipping: $270ish
So I'm wondering If anyone knows where to get the rear sway bar bushings and where the best place would be to get the upper control arm? Also is it worth it to get the camber adjuster bolts? I will be doing my own alignment so I would like to get it spot on if I can. Also if anyone has tips on replacing the bushings and carrier bearings that would be GREATLY appreciated since I know they'll be a pain in the you know effin what!
Thanks a lot guys!
Rock auto prices:
4 Moog Links: $120
Thanks a lot guys!
