PRSPlayer39
Hey Folks,
New member, but it's already been a huge help with my "new to me" LS.
Great car! Bought it to pile on highway commuting miles ... love the way it cruises the interstate! 2002 LS V8 Sport with just over 100,000 miles, but really good condition overall.
So bought it knowing it had a few issues to be resolved. Did enough homework to have a pretty good idea what those were. Had a front end clunk, replaced sway bar bushings (thank you forum DIY write up!) ... clunk gone. Periodic misfires, went ahead and replaced all coils with Visteon's and new plugs. Bought the valve cover gaskets too, but didn't find any oil in the plug wells, so skipped that part. Also went ahead and did a fuel filter while I had the front wheels off. Put some Seafoam in the tank just for good measure.
So prior to doing all this work, as I said, I had the skipping/misfire type issues. Also one time while accelerating it also seemed like it just died completely, but caught back in a second or two then ran fine. Not the same as the skipping misfires. Hoped one of the fixes above would take care of that.
So now it gets interesting ... after doing that work, the skipping misfires are gone. Mileage improved significantly and the car seemed to be running great.
Then I get the "seemed like it died" issue a few more times over the course of a few days. Took it out and blew it out pretty good one afternoon, seemed to run really well ... fun car to drive by the way. During this drive noticed a CEL, had the code checked ... 442 which is usually attributed to gas cap ... hadn't put gas in it in a week, had also driven a few days since the fuel filter replacement, so not sure on this one ...
The next morning tried to start the car and it did something like a backfire, but from under the hood. A lot of white smoke poured out from under the hood and into the cabin through the vents. What the &^% ... Looked under the hood all looked normal, no signs of oil leaks or anything. Started it again and it seemd to run fine. Now it's occasionally a little hard to start, still getting the periodic "seemed like it died" while accelerating every now and then. No codes get thrown from either of these events, just still the 442 that I haven't cleared.
So any ideas on what that backfire event was, and what are some things I should be checking for this hard starting and "seemed like it died" while accelerating issue. I've done numerous searches, but haven't really found anything that sounds like these symptoms (that aren't related to coils ;-)
Thanks in advance! Great forum!
