southernls
My car is a 2001 ls v6.  I have the overheating problem that many have described on this forum (mostly at slow speeds, stop and go, with a/c on).  I have looked at the hydraulic fan and it appears to be turning as it should.  However, if I hold it still when the car is started and then release it, it seems slow to get up to full speed.  Also, I can't tell a difference in the speed of the fan with or without the a/c on.
Could this be the actuator, or more likely the pump/motor?
I am tempted to replace the actuator, but want to have some idea that it will fix my problem. Any suggestions?
