htrdlincoln98
You dont want to sell th ecar and of all things get a honda? WTF
Anyways I think your mph are right on I have several of slipd in the 13.8 a few hundreds slower 98mph close to 97. Your cars running strong NA.
For the fuel pump thing I really cannt hear mine but, I'll bet you some $ it works.
How does you kit work. Is it activated by the TPS volts or an actual switch mounted to the TB. Either way I would assume that IF all is properly wired BOth will activate together?
As for the tune you sent me I still cannt figure that out either cause it most certainly didn't remove the speed limiter. With my new tune I did notice yesterday when running data logs @ 110 it almost felt like it was surging slightly. Might be running out of fuel also. But that was the first time I felt that. I'm changing the filter. To check. Whats the spec on these focus pumps.
