theophile
I am about to undertake a complete overhaul of the front and rear suspension on my '02 V8 sport. I don't know when it was serviced last, I can see torn/worn boots all around, and it's starting to squeak/clunk. I want to replace all wear items. I've searched and read extensively on these forums for everything I think I will need and have tried my best to source high-quality replacement parts at the best prices.
Below is what I am getting ready to buy. I would very much appreciate it if some of the veterans could take a moment to peruse the list and let me know what if anything I am leaving out. Also, if you have any comments about the parts/prices I'd welcome those as well. Thanks!
[table="class: grid"][tr][td]Part[/td][td]Number[/td][td]Brand[/td][td]Qty[/td][td]Rockauto[/td][td]Tasca[/td][td]Amazon[/td][/tr]
[tr][td]Ball Joint, Lower (Front) (16mm)[/td][td]K500085[/td][td]MOOG[/td][td]2[/td][td]$33.79[/td][td][/td][td][/td][/tr]
[tr][td]Control Arm (complete), Upper (Front Left)[/td][td]RK621665[/td][td]MOOG[/td][td]1[/td][td]$101.79[/td][td][/td][td][/td][/tr]
[tr][td]Control Arm (complete), Upper (Front Right)[/td][td]RK621666 [/td][td]MOOG[/td][td]1[/td][td]$101.79[/td][td][/td][td][/td][/tr]
[tr][td]Control Arm (complete), Upper (Rear Left)[/td][td]3063301[/td][td]Lemforder[/td][td]1[/td][td]$115.79[/td][td][/td][td][/td][/tr]
[tr][td]Control Arm (complete), Upper (Rear Right)[/td][td]3063401[/td][td]Lemforder[/td][td]1[/td][td]$115.79[/td][td][/td][td][/td][/tr]
[tr][td]Control Arm (complete), Lower (Front Right)[/td][td]RK80736 [/td][td]MOOG[/td][td]1[/td][td]$193.79[/td][td][/td][td]$166.58[/td][/tr]
[tr][td]Control Arm (complete), Lower (Front Left)[/td][td]RK80737[/td][td]MOOG[/td][td]1[/td][td]$193.79[/td][td][/td][td]$182.40[/td][/tr]
[tr][td]Tie Rod End, Outer (Front Left)[/td][td]ES800415[/td][td]MOOG[/td][td]1[/td][td]$35.79[/td][td][/td][td]$35.62[/td][/tr]
[tr][td]Tie Rod End, Outer (Front Right)[/td][td]ES800414[/td][td]MOOG[/td][td]1[/td][td]$35.79[/td][td][/td][td]$36.64[/td][/tr]
[tr][td]Tie Rod End, Inner (Front Left)[/td][td]EV452[/td][td]MOOG[/td][td]1[/td][td]$28.79[/td][td][/td][td]$32.16[/td][/tr]
[tr][td]Tie Rod End, Inner (Front Right)[/td][td]EV453[/td][td]MOOG[/td][td]1[/td][td]$28.79[/td][td][/td][td]$31.61[/td][/tr]
[tr][td]Stabilizer Bar Bushing[/td][td][/td][td][/td][td][/td][td][/td][td][/td][td][/td][/tr]
[tr][td]Stabilizer Links (front)[/td][td]K80261[/td][td]MOOG[/td][td]2[/td][td]$27.79[/td][td][/td][td]$27.30[/td][/tr]
[tr][td]Stabilizer Links, Left (rear)[/td][td]K80246[/td][td]MOOG[/td][td]1[/td][td]$30.79[/td][td][/td][td][/td][/tr]
[tr][td]Stabilizer Links, Right (rear)[/td][td]K80245[/td][td]MOOG[/td][td]1[/td][td]$30.79[/td][td][/td][td][/td][/tr]
[tr][td]Lateral (toe) link[/td][td]6W4Z-5B551-AA[/td][td]Motorcraft[/td][td]2[/td][td][/td][td]$119.23[/td][td][/td][/tr]
[tr][td]Shocks (front) (GREEN)[/td][td]6W4Z18124D[/td][td]Motorcraft[/td][td]2[/td][td]$83.79[/td][td][/td][td][/td][/tr]
[tr][td]Shocks (rear) (PURPLE)[/td][td]AT705G[/td][td]Motorcraft[/td][td]2[/td][td]$40.99[/td][td][/td][td][/td][/tr]
[tr][td]Shock Mounts (front)[/td][td]3W4318183AE[/td][td]Motorcraft[/td][td]2[/td][td]$38.79[/td][td][/td][td][/td][/tr]
[tr][td]Shock Mounts (rear)[/td][td]3W4Z18197AA[/td][td]Motorcraft[/td][td]2[/td][td]$47.79[/td][td][/td][td][/td][/tr][/table]
