What does overhaul Transmission mean?
Were the replies/feedback helpful?
  • Yes
    Votes: 1 100.0%
  • No
    Votes: 0 0.0%
  • Missing a little bit somthing....
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
dubs
NYC
I was just reading a post by a disgruntled owner who said that he had to do an 'over haul on his transmission.' What causes that? What test are preformed to determine if you have transmission issues? When you take in a car for a tune up, do mechanics perform tests to find problems or do they just optimize parts? Basic questions. Thanks for any feedback.
If you have ever driven a car with an automatic transmission, then you know that there are two big differences between an automatic transmission and a manual transmission:
• There is no clutch pedal in an automatic transmission car.
• There is no gear shift in an automatic transmission car. Once you put the transmission into drive, everything else is automatic.
Both the automatic transmission (plus its torque converter) and a manual transmission (with its clutch) accomplish exactly the same thing, but they do it in totally different ways. It turns out that the way an automatic transmission does it is absolutely amazing!
Just like that of a manual transmission, the automatic transmission's primary job is to allow the engine to operate in its narrow range of speeds while providing a wide range of output speeds.
Without a transmission, cars would be limited to one gear ratio, and that ratio would have to be selected to allow the car to travel at the desired top speed. If you wanted a top speed of 80 mph, then the gear ratio would be similar to third gear in most manual transmission cars.
You've probably never tried driving a manual transmission car using only third gear. If you did, you'd quickly find out that you had almost no acceleration when starting out, and at high speeds, the engine would be screaming along near the red-line. A car like this would wear out very quickly and would be nearly undriveable.
So the transmission uses gears to make more effective use of the engine's torque, and to keep the engine operating at an appropriate speed.
The key difference between a manual and an automatic transmission is that the manual transmission locks and unlocks different sets of gears to the output shaft to achieve the various gear ratios, while in an automatic transmission, the same set of gears produces all of the different gear ratios. The planetary gearset is the device that makes this possible in an automatic transmission.
