Sapperfire
are you still alive lmfao, i hope so if he made a post!!
Sadly He was killed...but he LIVED!
YouTube - Ice Age 3 The story of Buck
Yeppers, I still have a pause.
Not that I know of. Wont know till I get the measurements from someone.Does anyone else make inserts that could be made to work?
4 awg. Thats all thats needed since both sub amps are Class D mono blocks. The sub box is bolted to the car so it dont move and is hard to steal.
The sub amps are wired to run 1000 watts RMS each. So thats 2000 watts for the subs. A bit overkill but the dampening factor is very high so the subs really hit hard and have excellent attack and decay.
The main amp is 100 watts RMS per channel.
There is also an Alumapro capacitor bank wired to the sub amps and I have a custom power setup that has a 200 amp continuous duty relay that drops out when the system is off so that the capacitor bank does not stay charged when the car is off.
I know what I am doing. Not changing anything. There is only a .12V drop with the system playing full tilt on a 50hz bass note between the battery terminals and the post of the amps power relay.
If you do not know how amp classification works then you should not comment.
My headlights do not even flicker.
I have done over 3000 stereos and scored near perfect for my MECP.
How much current are you pulling through those wires, though?
120 amps during transient peaks of bass heavy music. Wont see above 70 during rock music playback. The type of wire, jacket material, length, ground length and cap banks are all variables in choosing wire size.How much current are you pulling through those wires, though?
And you, thats why I ignored your PMs about stereo questions. You think you know it all anyway and argue just to argue.Exactly..
I don't care how many installs you've done, 4awg isn't enough. Are your 1000rms amps pulling 50 amps each? Then it would be ok.
P.s. I might've missed it through the thread but are you using 1 or 2 runs of 4awg?
Pfft. Words.I don't buy into that strand count crap... and my EE friends can prove why it doesn't mean :q:q:q:q.
That being said 90% of systems I have ever seen had such :q:q:q:qty grounding and cable crimps that almost all their problems were solved right there.
You don't care how many systems I have done? Who the fock has more experience, me or you? Who has won many many DB drags? Who worked at an award winning shop for a decade? Who has installed over 100 $10K+ systems. Who here has passed MECP testing?
Me Sparky, not you.
I will admit to a mistake I made though. I have the amps at 2ohms so they are only putting out 600 watts RMS each. Total RMS power is 1600 watts. 1200 watts is at 80% efficiency.
