Replica ford fit rims on the ls
Blueberryyum02
Griffen
Will these fit the ls without any mods
FR09-18080-5108-45B1
WHEEL SIZE: 18x8
WHEEL OFFSET: 45
BOLT PATTERN: 5-108
HUB SIZE: 63.4
BACK SPACING: 6.27
CENTER CAPS: Center cap included, factory center cap will interchange.
Yes, they will fit. I was looking into getting these wheels in titanium for my LS, they come off the Focus ST.
I'm going with the black cause my ls is the deep wedge wood blue. But that's good to know I don't have to mod anything.
Yea you should be able to use any 2012+ focus wheels, 2013+ mkz and fusion wheels, 2013+ escape wheels, and 2015+ mkc wheels.
I wonder if they spec out for RWD cars? I never understood what would be the difference other than the RWD having a lot more side load on the front wheels vs. the FWD pulling the car around corners.
You guys must have been sleeping during search class.
The 2012 and newer Focus also has the 5 x 108 mm bolt pattern.
For information sake, here is a list of late model cars that share the LS bolt-pattern:
Ford
Escape___2013-2014
Focus___2012-2013
Fusion___2013-2014
Taurus___1986-2007
Thunderbird___1989-1997
Thunderbird___2002-2006
Transit Connect___2010-2013
Windstar ___1995-2003
Lincoln
Continental___1991-2003
Mark VIII___1993-1998
MKZ___2013-2014
Mercury
Cougar___1989-1997
Sable___1986-2005
Monterey___2004-2007
Jaguar
S-Type___2000-2008
X-type___2002-2008
XF___2009-2014
XJ___2004-2013
XK___2007-2013
Land Rover
Evoque___2012-2013
LR2___2008-2013
Volvo
C30___2008-2013
C70___2001-2013
S40___2005-2011
S60___2001-2013
S80___1999-2013
V50___2005-2012
V70___2000-2013
XC60___2010-2013
XC70___ 2001-2013
XC90___ 2003-2013
1995 Windstar wheels on my LS, Hahaha <knee slapper>
Lol, what?
Nice find, I've been trying to find a used set reasonably priced. I might just have to save up some extra pennies and get me a set.
Lol, what?
Rear Wheel Drive vs. Front Wheel Drive. I'm not sure if it's still the same, but for a long time wheels that were for or from a light front wheel drive car were not recommended for a heavier rear wheel drive car. I always figured it was due to the rear wheel drive putting a harder load on the front wheels in a hard turn under acceleration.
I thought FWD cars tended to need higher offsets due to cramming brakes, an engine, a transmission, CV shafts, and the suspension all between the wheels. Each part just pushes the brakes further out, so to keep the track width reasonable, the wheels are deeper. The LS has a peculiar high offset that resembles fwd cars. I would guess the double wishbone suspension is the reason for that. Most cars have MacPherson style struts, which tend to be more compact and get used in fwd applications. I could be totally wrong but that's my understanding...
I considered these a few months ago.i have a shopped picture around here somewhere...
its all about the offset and weight difference.
the big thing about the offset is
I thought FWD cars tended to need higher offsets due to cramming brakes, an engine, a transmission, CV shafts, and the suspension all between the wheels...
and of course a wheel designed for a vehicle that weighs one ton, shouldn't be used on a car that weighs two tons...
you wouldn't want to put a four lug escort tire from a car with 100ftlb of torque on a super duty with 800ftlb of torque, it would rip them apart... it doesn't have anything to do with the the way the forces act because of which whee is spinning.
Can you look around to find it or point us in a general direction, so we can help find it would like to see how the look on the vehicle.
For some odd reason I didn't get into the 20 and up rim fad.
To me it takes away from the look of the car. Plus I hate when I see people with 24inch rims on a stock suspension, and the wheels look like they pigeon toed, and knock kneed.
And a summer later they went broke and had to sell the rims and put the factory ones back on and still have the lift kit in place. Or they get a flat and have to ride on three 24,s and stock 16 cause they can't afford the rubber. I want some 18's to complement the look of the car. With out sacrificing handling and suspension, to say hey look I got twenty fours
Plus I'll sleep better at night. Cause the thieves will not look twice at my stock ford focus rims. Lol
One word of caution in using Focus of Fusion wheels on an LS - load rating. Just because is bolts up, has the right offset and may even be hubcentric doesn't mean that a wheel designed for a 2800-3200 lbs car will be safe on a 3800-4000 lbs car. Check the load rating info cast in the rim on the back side and compare that with the numbers on the factory LS rims.
