Removal
1. With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-02 .
2. Remove the rear brake disc. For additional information, refer to Section 206-04 .
3.
NOTE: If necessary, cut off one inch of the stud to ease removal.
Using the special tool, press the wheel stud out of the rear hub between the caliper mounting pads.
* Discard the wheel stud. Do not reuse wheel studs.
Installation
CAUTION: Never use air tools to install wheel studs. The serrations can be stripped from the stud.
1. If necessary, grind the head of a new wheel stud to a "D" shape to clear the wheel knuckle.
2. Position the new wheel stud into the hub flange, making sure the serrations on the stud are aligned with the serrations in the flange.
3. Install the wheel stud.
1. Place 4 flat washers on the wheel stud.
2.
NOTE: Do not use the wheel nuts that came with the vehicle.
Thread a standard wheel nut onto the wheel stud with the flat side against the washers.
3. Tighten the wheel nut until the wheel stud head seats against the hub flange.
4. Remove the wheel nut and washers.
5. Install the rear brake disc. For additional information, refer to Section 206-04 .
