OldSchool1
Me and Tim "OmniPresent" had an hour to kill so we replaced the passenger side front caliper and pads today.
Shut off the suspension switch
Jack up and support the car and remove the tire and wheel
Remove as much brake fluid from the caliper as possible.
Remove the hose from the caliber with a 10 mm box end wrench.
Remove the guide pins 17mm (OEM calipers did NOT allow for clearance to use a socket or box end wrench)
Remove the caliper assembly from the rotor. Remove the pads from the assembly.
Install the pads into the caliper. Install the caliper onto the rotor.
Install the new guide pins (do not lube).
Connect the brake line to the caliper.
Open the bleeder.
Fill the brake fluid reservoir.
Bleed brakes.
Reinstall wheel and tire.
Test and enjoy!
Open the bleeder.
Bleed brakes.
Test and enjoy!
