All of the center trim around the radio and toward the steering wheel pulls straight out. There is a single retaining screw hidden by the panel below the steering wheel so you have to lower it first, just enough to reach that screw. It's right below the little air intake for the HVAC temp sensor (which you should clean w/ alcohol while it's accessible).
Then you unbolt the screws that hold the radio in place.
