1. As you can see -- we got the software change done. Although there is a lot of work to do still, I thought I would open the site back up. If you encounter any problems -- contact me via the "Contact Us" link on the bottom of the page.
    Dismiss Notice
overheating again dtc's
Lincoln LS
  1. davidweb
    davidweb New Member
    Dec 4, 2016
    brookland
    overheated tonight,showing codes 1285,1299. cylinder head overheated,cylinder head temp sensor detected overheat.Does this indicate a blown head gasket?I'm tired of spending money on this car.
  2. joegr
    joegr Well-Known Member LVC Gold Member
    16,209
    3
    Dec 10, 2005
    Gulfport
    I'm sure you are having the same problem as almost everyone else has had. It can be fixed in one day or less, and won't come back for six or so years.
    You need to replace all the plastic cooling system parts.
    Please give the year of your LS, engine (V6 or V8), and the circumstances that it overheats in, if you really want help. If you want quicker help, then just search this forum. It has been covered hundreds of times.
Share This Page
