SultanGris
Where's the best place to procure these items? Too many visits to quick change oil places has rendered my plug leaky. Threads are getting bad. Thanks.
Yeah when I bought the car the oil pan gasket was leaking pretty bad, I tightened the bolts a little and it stopped. Unfortunately my plug threads are getting stripped and it's leaking there now, just a few drops overnight but next oil change I want a new pan for sure.The oil pan on the V8 is super easy to replace. You don't even have to move anything out of the way, just put the car up on ramps.
Anyone have a good source for those parts? Was looking at Ford parts giant but I'm not sure if the oil pan comes with gasket and plug, their description is unclear, thanks.
Ok, thanks!Usually, it would not.
Yeah that's normally where I get stuff too, they don't have much OEM stuff for the LS anymore though. So I've been getting them from Ford parts giant and some other place I forget off the top of my head right now.Rock Auto is my "go to" place for aftermarket parts. Simple website. Search by make, model, year... and engine.
Stay away from the cheap stuff... and buy name brand parts. IIRC... Ford used the same drain plug for most of their vehicles... My '95 F150 drain plug swaps with a few other Fords I have owned.
Just be glad you don't have an aluminum pan like the Escape V6 has. I had to heli-coil my son's pan when he stripped the threads in the pan.
