In answer to you question on O2 replacement, trade rule of thumb is, pre 96 every 60,000 mi and 96 and after ,every 100,000 mi...Having said that it is important to note, that a perfectly working O2 can be triggered to make the engine burn more fuel than before by faulty engine conditions...an oil burning engine can coat the sensor causing sluggish reaction and improper fuel mixture, even minor oil burning..left unchecked can cause total failure..a fouled plug, an even slightly burned valve , a vacuum leak can all trigger a rich mixture from an O2, by adding more O2 to the exhaust than normal...One more interesting fact , an O2 needs heat to work ,650 deg. , until the O2 reaches that temp it causes the engine to run rich...Some O2s have heaters built in to hasten the warm up time, if your sensor has 3 or 4 wires it has a heater , If the heater burns out the sensor works normal , just takes longer to come to temp..I hope this answers some questions...
