Joegr - Just making sure, you are aware that my setup is not physically attached to my intake right? As opposed to some of other questionable setups found here:
pics from weekend of CAI setup on 03+
In order for
my LS to hyrdo-lock, it would have to experience enough direct water flow through the bumper, up the corrugated tube, and then, saturate and come close to submerging the filter. In order to achieve these conditions, the car would have to experience a scenario so extreme, that it wouldn't make my setup that much worse than a stock one. Since the filter area is now open, I am not routing air/fluid to a fully enclosed area. In stock form, the airbox also has "feeds" on it for cold air induction - while not as direct as mine, would impose a similar amount of risk in a large puddle under acceleration situation.
You are valid in that a risk of hyrdo-lock exists, but I have put some thought into and tested my setup, and put fail safes into place to mitigate this event as best as I can while maintaining the benefits of additional cold air routing. For instance:
1 - the large hole in the fender/wheel well seen in my picture would act as a drain and the gap between my tube's flange mounted on the underside of the body allows an additional escape for water. These pre-filter fail safes will help in an extreme water collection scenario, preventing full submersion of the filter.
2 - I have driven in HEAVY rain, and immediately pulled over to observe the filter, which was dry.
3 - There are also minor drain holes in my tubing to allow for water escapes as well before traveling upwards towards the filter.
4 - Lastly, the most important variable, driver precaution is followed. Avoid puddles like you do potholes, animals, tailgating, etc.
5 - In the event any of these scenarios cannot be maintained and I am at higher risk, I keep a large softball in the car to wedge into the hole, preventing any water intrusion.
As an aside:
I might be, (and hopefully am) wrong, but I also think you like to troll me and my posts, which is unfortunate because 99% of your posts are effective and mature. I view you as an intelligent and overwhelming helpful poster, but on multiple occasions you have poked at semantic based posts of mine (coilpack vs coils, strut vs shock) and like to make it known that you dont approve of a majority of modifications. If your goal is to be helpful on here, which you are most of the time, than be just that - helpful. I can also be sensitive at times, so as the internet often goes, maybe we just aren't hearing one another enough. So I will close with saying that I mean no disrespect to you and your applicable knowledge in these discussions. But As I approach you and others on LVC with an objective mindset, I guess I just expect the same.
