Diplomat 1
If you haven't seen my other thread I have a 2003 LS v8 with codes 308 and 316. All plugs and coils have been replaced with motorcraft parts. I have swapped coils and plugs and still cylinder 8 has the misfire. I did a compression check and have good compression all around. I put a noid light on the fuel injector connector and it works. I tested for spark with a tester and see spark. Now I'm stumped. I was thinking maybe timing but someone said timing is set by computer. Here is a video of the misfire.
Does it sound like motor knocking? What other possibilities could cause it to misfire if I have spark fuel and compression? Could a clogged cat cause this? I am very confused please need major help frm you guys. Thanks
