Jibit
Dearly Departed Friend
Got my new struts yesterday, put them on without a problem. Lowered one end and then the other but the car was so low I couldnt' get the jack out from underneath so I turned the switch on and turned the car on. Immediately I get the check suspension. I then jacked the one end up and turned on the car. The compressor kicked on and aired up both. Two hours later and the car is slammed again to the point that I can't get the jack under the front end and the check suspension is coming on as soon as I turn the car on. So I jack the rear up and put another jack in the front. I released the rear and turned the car on again, the compressor turns on and inflates both struts. I turned the switch off and drove it into work this morning. I noticed that the car did drop when I got it up to speed (over 65mph) so when I got to work I turned the switch back on and let the car raise up and then turned the switch off again. I guess I'll wait to see if it drops when I get off of work.
