Front rotors/hub swap
greenehoosier
Southern Indiana
I have the Mustang front hubs and was shopping for the front rotors when I checked the front rotor diameters against the Mk VIII piece. I used a 1995 Mustang as my starting point. Do I need the standard rotors/V6 or the Cobra rotors? I am using the stock Mk VIII Calipers on the front. I did my search, I promise!
Thanks!
use mark viii and calipers mark viii rotors drilled or reamed out match the 5x4.5 bolt pattern. enlarging the stock holes with a grinder is fine.
if you use mustang rotors you will need mustang calipers and brackets.
