Flushing coolant
sneth
STL
Ok, it's getting cold and i need to flush my coolant system. I've done this on a few older cars, where all you did was unplug at the bottom, and run a hose through the top.
I have not done this on the Mark. I just had stations flush it for me. Anyone have an image showing the drain plug on the bottom? And, will the thermostat gonna mess with me draining the system? Or is there a DIY for this somewhere, it didn't come up in a search...
If it's too much trouble i guess i'll just go have someone flush it. I kinda need to go soon because it's 40 degrees out and i am running almost all water right now.
Turn your heater on full while you're flushing, so the heater core will get rinsed out along with everything else.
