Energy Bushings
If it's a sport, it should be right. Unfortunately, ES bushings are narrow and allow the sway bar to slide left and right.
google am auto parts. I believe they have what you're looking for. at the correct width for factory brackets.
get a cheap caliper and measure the sway bar width. get the black set, not the red. Its a different rubber compound in the red. Don't ask me what the difference is, I forgot. Once you have the sway bar width then you can check on the part. I used the ES, no problems, just finding the right fit, cause the sway bar is not perfect in dimensions. tip, disconnect both end links before working on replacement, makes it easy to slide the bar back & forth. By the way, the rubber boots are split down the middle for easy install.
Black has graphite (or some other lubricant) in the polyurethane, red doesn't
Acquire small 'cable-clamps' (look like small muffler clamps). They can be located in such a way as to preclude the back-and-forth movement.
KS
