2006kmls
The problem with electric supercharging seems to be that you can't get enough cfm from a DC driven fan/motor combination to build pressure in the engine. Anything out there that would run on DC requires TOO MUCH power to be reasonable or cost competitive when trying to get enough cfm to build pressure.
What about this:
This blower runs on 120 volts, makes 4100 cfm, and draws less than 15 amps at 120 volts a/c.
http://www.abbeon.com/adimage02/asupairpac.jpg
These are standard industrial blowers that you can get from a 100 sources. They are cheap ($500-$1000) and are precision blowers with tight roller bearing fan sections with SUPER TIGHT clearences and they build pressure.
What you do is add (1) extra battery in the trunk of the LS and tie the batteries together via an R/V isolator. During normal operation the LS's alternator "sees" and charges BOTH batteries, but only allows one to run the blower. You add a 200 amp alternator to the LS to make this efficient. These alternators are available for $200 (Powermaster). Then the one battery you added has a DC/AC inverter connected to it, whereas it has 120 volts coming out of the inverter. 20 amp inverters are available for less than $200 from a million sources. This 120 volts a/c then powers the blower.
You can use a switch for wide open throttle and just "turn on" the 4100cfm blower, which is fed with cold air and a filter and is plumbed into the intake tube. And you have a forced air blowerm with mega cfm.
You could also get fancy and get a TPS (throttle position sensor) to feed into an a/c frequency drive (0-5volts) and as the accelerator was depressed the a/c drive would speed up and slow down the 110v motor on the blower!
Why can't this work?
What about this:
