1. As you can see -- we got the software change done. Although there is a lot of work to do still, I thought I would open the site back up. If you encounter any problems -- contact me via the "Contact Us" link on the bottom of the page.
    Dismiss Notice
Drivers door wont open
Lincoln LS
  1. MysticMac
    MysticMac Well-Known Member
    168
    Aug 18, 2015
    Vancouver British Columbia
    I have been in the middle of replacing my window regulator motor and in the process my drivers door lock assembly has seemed to crap out on me or something. I do not have a handle installed on the inside of the door, only the outside. I can unlock the door manually by key but when I pull the door it doesnt budge. I am charging up my battery and going to try and unlock with my fob. Is there any way to get the door open manually from the inside?
    Thanks!
  2. joegr
    joegr Well-Known Member LVC Gold Member
    16,209
    3
    Dec 10, 2005
    Gulfport
    You have the interior mechanical cable completely disconnected?
  3. MysticMac
    168
    Aug 18, 2015
    no its still connected to the door lock assembly. Ijust removed the door panel, and peice of metal that was holding the handle, window motor.
  4. MysticMac
    168
    Aug 18, 2015
    I can unlock and lock it still from the insde using the cable. But it will not open
  5. joegr
    16,209
    3
    Dec 10, 2005
    Gulfport
    What all had you done to the latch assembly and the rods connecting to it in the process of getting to the regulator?
  6. joegr
    16,209
    3
    Dec 10, 2005
    Gulfport
    How do you know that you are unlocking it then?
  7. Andrizzle
    Andrizzle Well-Known Member
    5,016
    Mar 11, 2009
    Oklahoma
    Why did you take the handle off anyways...?
  8. MysticMac
    168
    Aug 18, 2015
    Lol, it was frozen.... I only removed the handle on the inside of the door. I removed the entire panel that holds the motor and handle.
    Sent from my iPad using Tapatalk
  9. MysticMac
    168
    Aug 18, 2015
    It's opened now. This is definitely a first for me and the dumbest thing to happen so far lol.
Share This Page
