AutoWeek is confirming the 412hp 5.0 for the '11 Mustang, following the breaking of an embargo by a loose-lipped Facebooker (isn't that redundant?).
The most interesting part of the article:
AutoWeek said:...What makes the brand-new V8 engine powering the 'Stang so potent is how engineers were able to allow the engine to breathe. All-new heads sit atop an all-new aluminum block with cast-iron cylinder sleeves. The wide distance between the heads allows for the intake ports to sit vertically on top of the engine. The engine features four valves per cylinder and twin independent variable valve timing. Tuned exhaust headers eliminate the need for aftermarket headers to let the engine breath better. Inside the engine are a forged-steel full counterweight crankshaft and four-bolt main bearings and high-performance pistons and connecting rods.
The new 5.0-liter Mustangs can be fitted with either the 6R80 automatic transmission or the MT82 six-speed manual.
-- http://www.autoweek.com/article/20091218/DETROIT/912189996
