2002 Deville will turn over but not start
tla528
PSL
Hello I have a 2002 cadillac deville and I took the engine out to change the front and rear main seat now I did not have my air gun to put the pulley back on the front shaft because my compressor stop working so I used a hammer and a block of wood to get the pulley back on the front shaft, and now I have put the engine back into the car but It will not start, but it was running fine before I took it out? I also changed the camshaft position sensor and the upper and lower crankshaft postion sensor that I got off of another Cadillac but still wont start!
I just checked my codes and alot came up but the one that I want to ask about is B3055; key not present, will that stop the car from starting?
Other codes are:
B1004 - Keep Alive Memory (KAM)
B0159 - Outside Air Temperature Sensor Circuit Range/Performance
B0249 - Heater/Defrost/AC Door Range Error
B0429 - Temperature Control #3 Rear Circuit Range/Performance
B1009 - EEPROM Checksum Error
B1327 - Vehicle system voltage below 9.0 volts
B3832 - Window Position Sensor Circuit
B3055 - Key Not Present
C1214 - System Relay Contact or Coil Circuit Open
C1248 - EBCM Turned the Red Brake Warning Indicator On
B1438 - IPC High Voltage Output Overcurrent to IPM
P0101 - Mass Air Flow (MAF) Sensor Performance
P0106 - Manifold Absolute Pressure (MAP) System Performance
P0335 - CKP Sensor A Circuit Performance
P0340 - Camshaft Position (CMP) Sensor Circuit
P0385 - Crankshaft Position (CKP) Sensor B Circuit
P0440 - Evaporative Emission (EVAP) System
P0442 - Evaporative Emission (EVAP) System Small Leak Detected
P0507 - Idle Speed High
P0532 - Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit Low Voltage
P0741 - TCC System Stuck Off
1106 - Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
P1633 - Ignition 0 Switch Circuit
U1000 - Class 2 Communication Malfunction
U1713 - Loss of Front Door Module to Window Motor High Speed Comm
U1714 - Loss of Front Door Module to Window Motor Normal Speed Comm.
U1065 - Loss of Communications with IPM
U1066 - Loss of Communications with RIM
Ok I cleared all the codes and then tried to restart the car but still wont start and some of the codes when away so here are the codes that are still in the car;
U1088
The code B1327 and B3055 are not there anymore, but I need more help with getting the car started and fix.
