will the 95 ECU auto-correct?
vr4
vancouver, wa
will it auto correct for fuel changes? if i wanted to put a fuel computer in will it try to change back to stock?
driller said:
I think you could safely say that's the primary purpose. It can only compensate so much however.
guess the only way ill know is to try.
98/99 3000gt vr4 will auto-correct 97 and older will not. what i mean is using an afc or other device to correct for larger injectors the ecu tries to bring the injectors back into spec by changing the pulsewidth. the afc manipulates the airflow signal to allow for larger injectors. the ecu doesnt like this and after a couple days you notice your AFR is way rich again.
obd2 fords will correct. since the 95 is obd1 im not sure if it will or not. could always say :q:q:q:qit and use tweecer.
