scjmc
I got the check advance trac, as well as ABS lights. I also have a nice audible warning and a message center warning. The code is for right rear wheel speed sensor input missing. I cleaned the ABS ring as well as sensor, and I also unplugged the connector and verified that the pins looked good. I still get the code, so I am assuming a bad wheel speed sensor. It could be the wiring, but has anyone had a RWSS failure? I searched and did not find any definate answers. My next question is if I replace it how important is OEM quality on this part? BWD is $66 and OEM is $100ish. Just wondering if anyone has used an aftermarket replacement...
If anyone has had a wiring harness related problem cause this issue please let me know.
