What to do with my Air Sys
Xrumer
Michigan
My rear is fine and my front rides a little high. I need to lower the front, but I don't have the tools or place to adjust the height sensor....
Any suggestions...
Dont have the tools? You dont have an adjustable wrench or pliers? And you dont need a place to do it, just turn the wheel you want to adjust outward and there is tons of room to get in and do it.
Advance Auto Parts will loan any of their tools. You dont need to jack the car up. Easy - 15 minutes tops.
really i thought u have to jack the car up and remove stuff. Does anyone have the instructions?
Ok, here ya go. Its really easy but BE CAREFUL when loosening the nut, in fact soak it good with penetrating spray, if you break the stud you are screwed.
Step one: Turn the wheel you want to adjust outwards.
Step two: locate sensor and loosen lower but just enough to slide it.
Step three: Raise sensor to lower front or lower sensor to raise front.
Step four: tighten nut just enough to be nice and snug, there is little tension on the sensors, no need the break them!
Keep in mind that a slight adjustment of the sensor has a great impact on the height. I would adjust no more than a quarter inch until you find what you want. I often do this with the car running to keep the auto-leveling active. You will also want to open the shut the doors numerous times to have the system re-check the height.
Sweet when it warms up (19*) today... i will do it and see how it works for me.
