what is it worth?
what are cobra brakes worth?
  • Total voters
    5
  • Poll closed .
zmt325
nashville tn
I have found a 1998 cobra with the front and rear brakes with front hubs/knuckles. I offered 300 we landed on $400 for all the brakes including front hub.
Is it worth it?
what else should I look for? the engine and trans is gone...
400 is maybe fair for all four corners.
300 is a good price for the complete front i would say. then whatever you wanna pay for the rear.
i would just get the fronts. its the main braking upgrade.
i am going with the mustang lug pattern. shouldn't i get the rear brakes?
and do you know where to get the adapter bracket?
so if i swap the rear hubs with 03 cobra hubs and use the brackets off sccoa with the rear rotors/calipers off the 98 cobra, what is the problem?
sounds good.
good again.
here's the problem. the brackets only work with the Mark VIII calipers.
the mustang calipers are a different design with different mounting and different parking brake actuation.
also, the mark viii calipers have a larger piston and a bigger pad. you want to keep them anyway.
use the Mark rear caliper.
sounds good.
good again.
thank you
one last question. after hub swap. can I run 20x10 wheels in the rear and if so what is the largest tire possable?
you can fit a 20x10 with a 45-48 or so offset. the offset is very important.
and you could probably run a 285, or maybe even a 295 tire.
