I cant see how a plug gap could cause his problem but it might if its way off.. Most of plugs I bought for the llsv8 were pre gapped and I never even bothered to re-check the gaps.
Also if you mix up the cops wires you don't deserve to be under a hood..
The wires in length are right where the cop goes lol...
if you were to plug cyl 1cop wire on the cyl 2cop or the cyl 5 cop wire on cyl 6 wire you wouldn't be able to plug the cyl 4 or cyl 8 and they aren't long enough to go the other way unless it doesnt have the original cop's wires :'')
And even if you damaged 2 or 3 cop wiring harnesses the car would still run with but with way less power, I was driving my ls on only 1 bank for a month never had to feather the gas but it ran like shit
But if your problem started just after the spark plug change thats where you should look,
maybe you got bad plugs that some asshole dropped on the ground and damaged them if they're the precious metal electrode type plugs, but like I said ^ this wouldnt cause the issue that you have to feather the gas to get goin.. sounds like its not getting enough fuel *@ clogged filter or strainer, injectors or weak fuel pump. a clogged in tank strainer could act the same as a weak pump and could burnt down your pump fast
