Transmission!!
Dubbed_LS
Somewhere in,
I KNOW THIS IS A REPEAT THREAD. BUT....
P0775 pressure control solenoid b.
SUCH A HEADACHE!!
TOOK IT SEVERAL PLACES MECHANIC SHOP AND SAID IT COULD BE THE TRANNY PUMP OR THE BATTERY BECAUSE MY BATTERY WAS BAD. AND THAT IT COULD CAUSE THE ELECTRONIC COMPUTER TO PUT OUT THE WRONG PRESSURE AND CAUSE THAT CODE TO COME UP.. REPLACED IT. STILL DIDNT FIX IT. AFTER OPENING IT UP AND LOOKING AT IT. THEY KEPT INSISTING THAT THE SOLENOID WAS FINE. THAT I NEED A WHOLE NEW TRANSMISSION OVERHAUL. *BLAH BLAH BLAH* QUOTED 3200 BUCKS.
THEN TOOK IT TO AAMCO TRANSMISSION SHOP. AND THEY SAID IT MIGHT NOT BE THE SOLENOID COULD BE THE MOUNTING BRACKETS OR I MIGHT NEED A NEW COMPUTER.
IF THE CODE COMES UP IS IT USUALLY 100% THAT THE PRESSURE CONTROL SOLENOID NEEDS TO BE REPLACED?
I'M TIRED OF SPENDING 85 BUCKS HERE AND THERE EVERYTIME JUST SO SOMEONE CAN LOOK AT IT AND IT'S STILL NOT BEING FIXED. AND IM DREADING TAKING IT TO THE DEALERSHIP BECAUSE THEIR LABOR CHARGES ARE RIDICULOUS. BUT I THINK IM JUST GOING TO HAVE TO SUCK IT UP AND TAKE IT TO THE DEALER.
ANY ADVICE OR PEOPLE THAT HAD THE SAME PROBLEM PLEASE HELP. ONCE AGAIN I KNOW THIS THREAD IS A REPEAT.
BECAUSE I HAD THE SOLENOID PACK REPLACED BEFORE. BUT I HAVE PUT ON 20.000 MILES ON IT SINCE IT WAS REPLACED.
while your at the dealer, have them replace your faulty CAPSLOCK soleniod as well.
It's a recall item and it's a free repair and your is obviously faulty
