is it possible to completely drain the fluid from the pan through small fluid level plug? or does the bigger one have to be takin out too
i took out the small one fluid came out for about 10/15 secs...can't find the tool to open the bigger one so i need to know if it's necessary to open the bigger one
The small one is just to check the fluid level. When you take it out, a small amount should trickle out if it is correctly filled.
You have to remove the outer plug to drain the pan.
"When you take it out, a small amount should trickle out" this did not happen about 1 liter of fluid came out I did this in the morning the car was off all night and was not in idle
I removed the drain bolt and another liter (approximately) came out
should the gasket around the drain pan and transmission filter be replaced? the cars only got 43000miles on it
thanks
i plan on doing two more drain and fills
how many miles will it take to get the new fluid mixed with the old? around the block? on and off the highway? or wait until next oil change which will be in 3000kms
if you pull out the drain pan you could get away with filling up the drain pan with 4-5 liters of fluid then have someone hold the pan in place while you put the screws in beats pumping in 4-5 liters
to check transmission fluid level 2004 Lincoln LS Automatic
1. turn car on wait/drive until normal operating temperature
2.run through all gears
3.put car in park leave car on and put the car on hoist
4.unscrew the small screw that's in the middle of the bigger one
if fluid drips out or becomes a thin stream the fluid is at the correct level
is this right i want to be sure
