02 ls8
has anyone done a 5spd swap or a triptronic swap into a gen 1 v8?
feedback? thoughts?
feedback? thoughts?
You can add the SST funtion to a non SST auto ls very easily. You would just need the SST benzel and the shifter I think. I tried looking for the thread I saw the info in but when I type in "SST" nothing comes up. Search functions neds some refinements. Swapping a manal tranny into an ls would be pretty expensive but possible with enough money
all LS transmissions are electronicly controlled - so to add SST function all you need to do is swap the shifter.
the manual swap in not possible - until someone can reverse engineer the PCM code to that level.
Speaking to the manual part of the OP's question, you'll need:
1. Custom bell housing---available from Quicktime
2. Flywheel and clutch---available from McLeod or Hayes
3. Hydraulic throw-out system---available from McLeod
4. Transmission from Tremec or Richmond
5. Driveshaft from Motorsport with local mods
6. Re-flash to eliminate transmission connections
KS
does anyone know or have a step by step to switching out my reg. shfiter for the triptronic its a 2001 lincoln ls
