MercuryLs
So if your read my other thread I just finished an engine swap in a 2000 LS V8. I did a trans filter & fluid (Mercon V) change while doing the swap. The car has 145,xxx miles on it.
Anyway, the car is up and running. I filled the trans as your supposed to. When I drive the car it does not shift up into 4th or 5th, it will only go as high as 3rd. When going WOT the 1-2 and 2-3 shift feel sloppy.
The car throws: P0734, P0735, P0795 codes and of course says "Check Transmission"
So am i looking at a Valvebody & Solenoid Pack change? Or does it sound like a new trans is where I am headed?
