supercut
Can anyone tell me which is the best fit transmission for a 1998 Lincoln Town Car Swap...Engine is a 1995 Ford 351 Windsor...Im trying to use factory drive shaft, Transmission cross member, and mount....so far the Towncar transmission won't bolt up properly...only the top two bolts and driver side bolt will work and the rest is open space..Now I need to know what would be a better option... I forgot to mention that the engine came out of a 1995 Ford Truck... Im not sure if that will work either...
