Tire Rubbing
wboyne
Sterling Heights
I recently purchased a 1995 Lincoln Continental that had the spring conversion done already. I needed a new front passenger tire so I purchased the stock size 225-60R16. The tire is rubbing the plate thing on the bottom of the coil spring. Checked the ball joint and that is good. What can be causing this? Should I get a narrower tire? Or will an alignment fix it as it looks like the camber is off (toe out). Thanks for any advice.
