eL eS
I have a lot of miles on my LS, well 108k, and 99 percent of them are hwy which had resulted in some bad pitting of my fog light lenses.
Over the weekend I took a leap of faith and tackeled the pits. I started out with an 800 grit paper which might have been a bit coarse for the job. I then moved to a 1000 grit and then 1200 on to a 1600 grit. I then polished the lese off with a product similar to scratchX.
The 800 seemed a bit coarse at first but they cleaned up very well as I progressed to a finer grit. I do a lot of work with plexi and have used rougher grits on the platics so I wasnt concerned with polishing it out. I think the 1000 would have been sufficiently coarse to cut the pits and scrtahces.
I did the entire project with them installed. It would have been easier on the back and knees if I would have removed them plus had I taken them out I could have put them on the buffing wheel and really worked them over but they look great as is.
I replaced the bulbs a while back with the Siler Stars that are used on the high beam, I think they are the 9005, but the lense was too pitted to really let em shine. Well you can tan under them now.
I wish I would of had the sense to take photos along the way. The results are fantastic. I had a similar problem with my Contour SVT head light lenses hazing up and used 1600 and polishing compund to remedy that problem.
Have any of you faced this problem yet?
