Guys
Does anyone have a diagram of how the driver side airbag is connected? Does the harness connector go right into the airbag, or is there a piece that sits in between: i.e. the connector connects to something, which in turn the airbag is connected to.
For reference: I have had the 3-6 airbag code flashing to some extent for the last three years. So far, I've done the following, and each step has reduced the recurrence of the problem.
1 - Dealership replaced underseat connector. Problem went away for about 4 months
2 - Dealership retraced all wiring in the seat airbag harness. Problem went away for about 6 months
3 - Dealership replaced driver side airbag. Problem went away for about 5 months
4 - Replaced driver's underseat connector myself by hardwiring. Problem went away for about 4 months. Once this was done, I could get the light to go off by whacking the seat with my elbow and re-starting the car.
5 - Replaced the seat airbag connector. Problem went away for about 2 months. The light has started flashing right after I lean back in the seat. I can get it to go away by whacking the seat with my left elbow right at the level of the airbag. It stays off up to 5 or 6 weeks.
The problem is in the connection to the airbag. I'm just trying to find out how that connection works and why mine is a little loose.
