CobraConti said:
I would love to see this. No telling how much that would cost. It would be fun though.
Anything is possible, and the swap is realistic. I thought about the swap in my 2002. An Eaton would be the only way to clear the hood. These days, you can find the Eaton blowers on ebay for under $500 now. My cousin got one for $350, ported it, and installed it in his Mach I. If you look at the Lightning SC, it has an opening for the throttle body facing upward like the Conti/ Gen-I Mark VIII intakes, making the Lightning Eaton the best candidate for such a swap. But I'm not sure it will bolt-up to the C-head lower intake yet...
The tricky parts for the Conti would be the intercooler and wiring and the tight space in the front accessory drive. I don't think two belts would fit without a little shoe-horning and inginuity.
Another obstacle would be that damn AX4N transaxle, which is already being pushed to the limit by the 32-valve. The only solution I could think of is a Gen-III SHO Taurus manual (Mazda manual transaxle). That TA can handle planty of power, though I am unsure of its maximum capabilities.
As for cost, it wouldn't be no chump-change project, but would be the only known Conti with a blower on top, as well as a very unique vehicle. From head-to-toe, ballpark cost; blower, internals, Mazda manual transaxle swap, intercooler, accessory drives, wiring, possible custom fabrication work, custom tune: $6,000 to $10,000 to make it work correctly. The cost would depend on used or new parts, install costs, machining, etc, unless you did all the work yourself.
Image the look on some Camaro guy's face if he were beaten by his grandmother's car... :gr_devil:
