Stereo swap fail
Lincoln LS
  1. Four eyed stangs
    Four eyed stangs Active LVC Member
    95
    Apr 9, 2012
    Chandler
    I installed my deck using http://www.amazon.com/gp/product/B000YR6C2E/ref=oh_details_o00_s00_i01 cable set.
    The unit works, but the SW is mute.
    It was a bear getting the SW plug to go into the car's plug.
    Out of the four rows of pins, the adapter plugs into two.
    It looks like the spacing is off and one row is blank.
    Do I have the wrong SW plug?
    My Pioneer deck has coaxial RCA type SW out 2 chan.
    Thanks
  2. Four eyed stangs
    95
    Apr 9, 2012
    Chandler
    Alpine 6 disc system
  3. Four eyed stangs
    95
    Apr 9, 2012
    Chandler
  4. marcredd
    marcredd Dedicated LVC Member
    3,069
    23
    Feb 17, 2007
    Ironton
    Loud is the resident stereo tech. He should see this post by tomorrow evening and should be able to shed some light into your question.
  5. grotty101
    grotty101 IS AWESOME
    98
    Mar 17, 2012
    Pardeeville
    Is the subwoofer output turned on, on the deck? I know its kind of obvious and I'm sure your aware it can probably be turned on and off.. but I have seen people leave it turned off and then rage that their subwoofers don't work.. lol
  6. 1LoudLS
    1LoudLS Dedicated LVC Member
    9,901
    350
    Mar 31, 2008
    Ann Arbor
    the little plug should have no problem plugging right in, the white little plug in your link is the correct plug, just some of the pins are probably a little out of line and need to be slightly bent.
    you need to plug the RCA in to the radio, and then hook up the blue wire to the radio's amp turn on wire (you will need a resistor to keep the amp from "popping" when it is turned on and off)
    personally, i would leave the center channel speakers un hooked, they are designed to be used with a specific sound processor that a new radio wont have.
  7. Four eyed stangs
    95
    Apr 9, 2012
    Chandler
  8. Four eyed stangs
    95
    Apr 9, 2012
    Chandler
    What resistor do you suggest?
    The pop is a bit startling!
  9. joegr
    joegr Dedicated LVC Member
    19,530
    1,422
    Dec 10, 2005
    Gulfport
    About 1KΩ to 2KΩ seems to work well.
  10. 1LoudLS
    9,901
    350
    Mar 31, 2008
    Ann Arbor
    1450 ohm is what i have at work that works well.
Share This Page
