jasond
02 LS V6, very clean, 76k miles. Throwing a P0745 and a P0795 once the trans heats up. Seems to not want to shift into 4th and/or 5th gear (i think... I do know it's holding a lower gear). Works fine when cold.
I was hoping to get away with routine service plus a solenoid pack and a shift kit. I am a good enough wrench, but decided to send this job out.
Small owner/operator shop, guy is familiar with the 5R55N's innate flaws. He drops the pan, fluid is somewhat dirty (he says this is the clutch coming apart), some metal bits stuck to magnetic plug.
He is recommending a rebuild, including a re bore and re sleeve of the pistons, new torque converter, etc, says that a rebuild will correct all the design flaws.
Quote is $1500, which is very fair, but I am still not convinced that a full rebuild is needed. Any thoughts anyone might have would be greatly appreciated!!
