Everything you take out on the exhaust cam has to go back in the same way, including the bolts, they have to be torqued back down in a certain order and must be torqued to spec and then an extra 1/4 turn afterwards.
It has to be seated the way it came out or there will be troubles.
Valve cover bolts 89 in.lb
Camshaft Bearing Cap Bolts
Stage 1 Hand Tighten
Stage 2 6 Nm (53 in.lb)
Stage 3 Additional 90 degrees
If you are not lifting the intake cam then you skip those sequential numberings and keep the count on only the exhaust cam.
Do yourself a favour and make a cardboard cut out, trace the top of the entire cam and make holes, place all your bolts into those holes as they came out. The cam bearing caps are numbered and have to go back the same order and orientation they came out.
It's all in how it was seated and worn until this point in time, you put it back out of original and it will not like the offset of how it sits.
All Bolts and Bearing Caps *have* to go back in their original locations.
Good Luck !
