Addendum to post by Marcus
This will take about an hour of your time. This is intended to bypass the
engine soak timer and clears the P1000 code and resets the OBDII
monitor status.
After reading this, map out your route so you can take the appropriate
roads, sidestreets or freeways/interstate to get this done.
When performing the OBDII drive cycle, your tank should not be more
than 3/4 full but not less than 1/2 empty.
Alter your driving style in a smooth fashion accelerating with a steady foot.
This is important as to keep fuel slosh to a minimum.
Follow the steps as accurately as you can.
1) Begin drive cycle by starting the vehicle and let idle for 15 seconds.
2) Cruise at 40mph for 4 minuites. Bring vehicle to a stop.
3) Cruise between 45mph to 65mph for 10 minutes. Bring vehicle to a stop.
4) Drive in stop and go traffic condition. Include five different cruise speeds
ranging from 25mph to 45mph for 10 minutes. Bring vehicle to a stop.
5) From a stop, smoothly speed up to 45mph. Slow to a stop.
6) Repeat step 5
7) Repeat step 5
8) Idle in Drive position for 2 minutes.
9) In Overdrive position, Slowly cruise to 50mph for 15 seconds then bring vehicle to a stop.
10) In Normal position, Slowly cruise to 40mph for 30 seconds. Continue...
11) While in 40mph cruise, shift to Overdrive and speed up to 50mph
cruise for 15 seconds, then bring the vehicle to a stop.
12) Repeat step 9
13) Repeat step 10
14) Repeat step 11
15) Repeat step 9
16) Repeat step 10
17) Repeat step 11
18) Repeat step 9
19) Repeat step 10
20) Repeat step 11
21) Repeat step 9
22) Repeat step 10
23) Repeat step 11
24) Repeat step 9
25) Repeat step 10
26) Repeat step 11
27) From a stop, Cruise to 65mph, let off the gas - no brakes, slow down to 40mph. Continue...
28) From 40mph, Cruise to 65mph, let off the gas - no brakes, slow to 40mph.
29) Repeat step 28, then bring vehicle to a stop
End of Drive Cycle
Lux, Good Luck on your inspection
Ren/Octane
